Closed Thread
Old 02-27-2010, 11:35 PM   #1
Shade Tree Mechanic
Installing a gas line, pre-planning
First post here, and I'm wondering if you might be able to help a bit! I've run short runs of gas pipe with success, but my new place looks a bit more challenging.
The main gas line of the house runs along the inside of the steel I beam that supports the house, and branches off perpendicular (same side) to a utility closet that houses the furnace and hot water heater.
I want to add a tee, and continue that line another 30 feet, bring the line up and over the other side of the I beam (opposite side), and through the floor. The basement is finished, and I'm curious if I would have to install a short drip line at the I beam, or right underneath the line that will go up through the floor to a new gas range. If so, how long?
Any other pointers on fishing this run over the I beam would be appreciated as well.
Thanks in advance.
Only a Pro can pull a permit & do gas work in your area
Please hire a Pro
Last edited by Scuba_Dave; 02-28-2010 at 05:59 PM. Reason: Gas work not allowed by DIY homeowner
ignition is offline
Old 02-28-2010, 06:01 PM   #2
Xtreme DIY'r
Thread closed
Scuba_Dave is offline
Closed Thread
Can a roof vent identify where my main sewer line exits the house? YerDugliness Plumbing 8 01-26-2010 05:13 PM
Installing a Gas Line for a Jen-Aire.... LAHKATY Remodeling 3 11-19-2009 08:58 PM
Any tips or tricks on installing a line set ? tuckerz HVAC 10 11-04-2009 07:24 AM
Locate Return Recirculating Line Farmer Dean Plumbing 4 02-20-2009 07:47 AM
Replacing damaged BX line in kitchen wall fishnyc22 Electrical 5 02-17-2009 01:40 PM
