Old 10-24-2012, 04:37 PM   #1
TedH's Avatar
Installing gas line to outside grill
October in Phoenix is absolutely the best time of year for outdoor grilling and soon the evenings will be perfect for sitting around the fire pit. We've decided to run a gas line from our external gas meter from the side of our house, under a block wall into our back yard for about 80' to an area we currently have a wood burning for pit. I haven't a clue what the City of Phoenix "code" requires but a 20" deep trench along the edge of our stem wall and patio should be pretty straight forward and I'm thinking I can do it myself. Any advise would be greatly appreciated.
TedH is offline   Reply With Quote
Old 10-24-2012, 06:42 PM   #2
are you certified to install and test gas lines according to your local code and to your gas supplier requirements .....if not.. best left to the pros....sorry but it is gas ....ben sr
The Following User Says Thank You to ben's plumbing For This Useful Post:
joecaption (10-24-2012)
Old 10-24-2012, 07:58 PM   #3
TedH's Avatar
Thanks Ben, I appreciate the fact that professionals should be utilized when necessary but this is an external install and I can't imagine it would be too difficult. No, I'm not certified to pressure test gas lines but I've run 220 volt electrical wiring and I'm not a licensed electrician either. I just like to do little projects myself and if this is something I can do with input from others then great; if it's really all that complex or dangerous to me or others then of course I'll hire a pro.
The Following User Says Thank You to TedH For This Useful Post:
ben's plumbing (10-24-2012)
Old 10-24-2012, 08:16 PM   #4
it will have to be tested and inspected....so it will have to be up to code according to your area ..my area will not inspect any gas line work that is not done by a certified installer...before you start check with your local,,,ben sr
Old 10-24-2012, 09:07 PM   #5
TedH's Avatar
Wow, well I guess the real estate market is bad enough without all us DIYers blowing up half of our neighborhoods. Better get a pro or just keep burning wood in the pit. Thanks Ben!
DIY Comedy--PVC for main water line? Daulton Plumbing 8 03-23-2011 10:03 AM
Can a roof vent identify where my main sewer line exits the house? YerDugliness Plumbing 8 01-26-2010 05:13 PM
Installing a Gas Line for a Jen-Aire.... LAHKATY Remodeling 3 11-19-2009 08:58 PM
Any tips or tricks on installing a line set ? tuckerz HVAC 10 11-04-2009 07:24 AM
Do I need to prime my oil feed line? 1parkpointer HVAC 3 10-22-2009 07:52 PM
