Installing "Flexible Corrugated Copper Water Heater Connector" - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-19-2010, 08:27 PM   #1
Rewards Points: 135
These have 3/4" FIP fittings and a gasket (not cone) in them. Do I use teflon tape to connect to a 3/4" pipe nipple, after all, both are tapered. The watts connector I have offers no instructions, just "Do Not Overtighten" on the tiny tag. I think I may have cranked the hell out of one that eventually leaked. Not sure if I used tape or not on that one...
smata67 is offline   Reply With Quote
Old 05-19-2010, 08:55 PM   #2
Rewards Points: 1,088
I have no experience with these, but someone recently created a thread about how he regretted installing one of these.
handy man88 is offline   Reply With Quote
Old 05-19-2010, 09:20 PM   #3
Rewards Points: 352
no tape necessary
plumberinlaw is offline   Reply With Quote
Old 05-19-2010, 09:20 PM   #4
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Do not use tape. Tighten them hand tight, then go about 180 more degrees. That should hold major amounts of water. Pressurize the system and check for leaks. Tighten as needed to stop any further water coming from the joints.
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
MACPLUMB (05-19-2010)
Old 05-19-2010, 09:57 PM   #5
35 YEAR MASTER PLUMBER
MACPLUMB's Avatar
Talking
JUST AS A HABIT THAT I DO ON ALL STEEL PIPE THREADS IS A LITTLE
TEFLON TAPE AND THEN SLIC-TITE TEFLON DOPE OVER THREADS
THAT BEEN SAID IF THEY ARE NEW NIPPLES YOU DON'T NEED ANYTHING ELSE
THAT IS WHAT THE RUBBER WASHER INSIDE THE NUT IS FOR TO MAKE A
GOOD WATER TITE SEAL
JERRYMAC@UTAHWEB.COM
35 YR. MASTER PLUMBER WITH PH.D IN WATER HEATERLOGY, MASTERS DEGREE IN DRAINLOGY,
PLUMB ANY PIPE, SNAKE ANY DRAIN, MAKE COLD WATER BOIL ON A FREEZING DAY
MACPLUMB is offline   Reply With Quote
Old 05-20-2010, 07:23 AM   #6
Rewards Points: 135
That was me! I've decided to try and get it to work and put off "doing it right" until the water heater craps out. No question, I'm never using compression or this type of connections again, all sweat from here on out.
Old 05-20-2010, 08:56 AM   #7
Doing it myself
Alan's Avatar
Why not?
Journeyman Plumber
Old 05-20-2010, 01:13 PM   #8
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
unless you live in an earthquake zone i personally wouldnt use them either,very unprofessional looking much like trac-pipe imo anyway
plummen is offline   Reply With Quote
Old 05-20-2010, 09:11 PM   #9
Flex connectors will last for years if installed properly.
MR. Mr. is offline   Reply With Quote
The Following User Says Thank You to MR. Mr. For This Useful Post:
MACPLUMB (05-21-2010)
Old 05-21-2010, 12:24 AM   #10
Doing it myself
Alan's Avatar
Doesn't a water heater installation require an earthquake strap anyway?
Journeyman Plumber
Old 05-21-2010, 11:08 AM   #11
plummen's Avatar
not in nebraska anyway!
Old 05-21-2010, 12:21 PM   #12
Household Handyman
Rewards Points: 1,408
Earthquake straps? Not in GA. Not since my first wife walked out, now when she walks across a room=Earthquake! Don't know if we've ever had an earthquake in the 61 years I've been here. I install electric water heaters in my business. The only way I will use those flex copper tubes is if I'm running late in the day, I don't have something I really need in my trailer, and I can come back tomorrow to finish the job rather professionally. I've seen those flex pipes develop pin holes, usually within the bottom of the corrugation and on the outside of the bend --where the water flows against the tubing. David
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 09:55 PM
Gas Hot Water Heater - Help? MaximumAsh Plumbing 22 03-13-2009 10:57 AM
Installing a tankless water heater ? bdalekid Plumbing 3 02-26-2007 07:26 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
