Old 09-26-2008, 11:51 PM   #1
Installing flat bottom vessel sink. Please help!
I have one question:
I have a flat bottom vessel sink that I need to install in my bathroom. The directions appear to tell me that I need to cut a 4" * 4" square hole in the top of the counter. I just want someone to verify if that sounds correct (comes with a template). I want to make sure I'm reading the directions correctly!
Thanks,
Schmidty
Schmidty is offline   Reply With Quote
Old 09-27-2008, 12:23 AM   #2
Since I cannot see the rest of the installation instructions, or the sink, I guess all you can do to test this is use a piece of scrap wood and cut the opening to see what it's function is. I would definatly do this before cutting the countertop.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
More On This Topic
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are doing a frame walk and insulation inspection on this home. I want to talk here a minute about compression. Compression in an insulation inspection is... Read More »
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are doing a frame walk and insulation inspection on this home. I want to talk to you for a minute about these arched windows like this. Okay we've put... Read More »
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are doing a frame walk and insulation inspection on this home. The thickness of our insulation is going to make a difference in the R-Value. So if we have... Read More »
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are doing a frame walk and insulation inspection on this home. What we are talking about here is we are talking about the envelope of your house. Think of... Read More »
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are doing a frame walk and insulation inspection on this home. The next thing on our list is going to be the garage band joist air barrier. What that is... Read More »
Installing a utility sink BNPadgett Plumbing 1 05-03-2008 10:49 AM
Vessel sink doesn't drain completely Lin Plumbing 3 04-25-2008 12:35 AM
Did I ruin toilet/vent after installing sink??? nibeck Plumbing 1 04-22-2007 01:32 PM
installing vessel sink drain?! (HELP!) tara Plumbing 2 11-10-2006 01:17 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
