Old 07-28-2012, 09:15 PM   #1
Installing flange over uneven drain pipe
I need to install a flange over a corroded, uneven, cast iron drain pipe. How do I level the pipe or raise the edge of the flange to get it level when installed? Will it leak underneath if the flange isn't sitting flush with the floor? Any suggestions would be appreciated.
cburke517 is offline   Reply With Quote
Old 07-28-2012, 10:28 PM   #2
picture of what you have will help us help you....
ben's plumbing is online now   Reply With Quote
Old 07-28-2012, 10:48 PM   #3
Why not just cut out the cast and replace it with PVC?
A simple hubless connector will reconnect the PVC to the cast.
Old 07-29-2012, 09:42 AM   #4
I tried to download some pictures, but my computer and the thread wouldn't make that happen. I'm wondering if I'm not explaining it well. Let me try again. My toilet flange is not sitting flush and level with the floor. How do I level off the pipe or make the flange sit flush/level with the floor?
Old 07-29-2012, 01:23 PM   #5
call me E
TheEplumber's Avatar
What kind of flange are you using? Is the pipe in concrete or do you have access to it?
Old 07-30-2012, 05:40 PM   #6
I think I have it! Once the tiles were put into place the flange sat level on top so this problem was mute. Toilet installed and working great. Thanks for those who replied!
Drain pipe leak, quick fix? KE2KB Plumbing 15 02-15-2012 09:57 AM
Toilet Flange Inside or Outside Drain Pipe? sledged Plumbing 23 01-18-2012 01:18 PM
drain pipe slips off tail pipe tomad51 Plumbing 4 07-04-2011 03:06 PM
Washing Machine Drain Pipe tjeieio Plumbing 2 02-25-2010 06:19 PM
Leak at flange and drain pipe tallycat77 Plumbing 1 07-26-2005 09:32 PM
