Installing Faucet With Cold Water Only - How To Cap Off Hot Water Inlet? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-26-2009, 09:38 AM   #1
Installing Faucet with cold water only - How to cap off hot water inlet?
I have installed a faucet in my garage and have only plumbed cold water to the faucet. I need to "cap off" the hot water inlet so the water does not come out there. What is the best way to do this? A pvc screw cap? What size is the faucet inlet?
jrterry1976 is offline   Reply With Quote
Old 02-26-2009, 10:00 AM   #2
The best way would be a cap 1/2'' iron pipe size
plumbbum0203 is offline   Reply With Quote
Old 02-26-2009, 11:33 AM   #3
Registered User
Termite's Avatar
Assuming the threads on the faucet are metal, I'd get a bronze or galvanized threaded cap and use some pipe dope or teflon tape to seal it up.
Old 02-27-2009, 07:27 AM   #4
plumbing contractor
PLUMBINGITALL's Avatar
Just another idea is to put a dual stop on the cold water stuped out of the wall and hook supply lines to the hot an cold side of the faucet. This way you will not have to plug anything. It will also help keep the hot stem free off trash and depre.
PLUMBINGITALL is offline   Reply With Quote
Low water pressure in kitchen faucet after replacing water heater SusanonDaffodil Plumbing 8 01-27-2011 01:28 PM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
advice on cold water pipe in basement garage area cambie Plumbing 6 10-15-2008 01:29 PM
Help! hot water won't stop running despite faucet changes. nodak_luke Plumbing 4 12-14-2007 05:38 PM
