Installing Exterior Faucet To Washer Line? - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-15-2006, 05:49 PM   #1
Installing exterior faucet to washer line?
I need to put a garden hose spigget on the outside of my house. My only option short of running 12 feet of copper line from the cold line on other side of my house is to tap into the cold line that feeds the washer.
This line is in the basement, comes up to the kitchen and is on the side (driveway) that I want the faucet on. Is this allowabe by code in upstate NY or do I have to run that 12 feet of copper line and tap into the main cold water line?
I'd be tapping into these lines from the basement.
Thanks.
skellies is offline   Reply With Quote
Old 06-15-2006, 06:36 PM   #2
It should be OK.
You may want to install a frost free valve so that it will not freeze in the colder months.
redline is offline   Reply With Quote
Old 06-18-2006, 06:25 AM   #3
Frost free
Yep... Install the Frost Free valve..... or make the Spigot at the end of the line with a on/off valve inside the house so it can be drained.....
mdlbldrmatt135 is offline   Reply With Quote
Old 06-18-2006, 09:19 PM   #4
Al
Out side Spigot
Skellies
the N.Y.S. Plumbing Code does not address this, sooo it's ok to do it. Do it like Md and Redline suggest
the man is offline   Reply With Quote
Installing basement shower drain atilla137 Plumbing 5 09-03-2009 12:54 PM
Condensate Line schott HVAC 17 06-02-2008 04:16 PM
Washer drain peloncito Appliances 7 08-04-2007 01:56 AM
how to run fridge water line under kitchen floor? travishume Plumbing 23 09-26-2006 08:51 AM
Location of 220 and 110 outlets for dryer and washer JAJJ Electrical 2 08-07-2006 10:16 PM
