Installing Drain For Shower Base - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-22-2013, 11:16 AM   #1
Installing drain for shower base
Hey Guys,
I am installing a shower base and I am having trouble finding a drain kit for my shower. I need something to connect the drain to the 1.5 waste pipe.
http://www.lowes.com/pd_150584-7-721...eft&facetInfo=
nyc_nhp is offline   Reply With Quote
Old 07-22-2013, 11:50 AM   #2
Rewards Points: 34
Your shower drain pipe is supposed to be 2 inches.
Dan
djlandkpl is offline   Reply With Quote
Old 07-22-2013, 11:56 AM   #3
Rewards Points: 3,130
Indeed. 1.5" is fine for tub/shower combinations, but just a shower requires a 2-inch drain.
Old 07-22-2013, 12:22 PM   #4
but my cast iron pipe is 1.5", how would i go in there with a 2" drain pipe
Old 07-22-2013, 01:28 PM   #5
Rewards Points: 1,956
http://www.fixtureuniverse.com/produ...src=aw.ds#aDim
Old 07-23-2013, 07:02 AM   #6
You wouldn't. The entire drain needs to be replaced with 2-inch if you want to be code compliant.
Old 07-23-2013, 11:10 AM   #7
If he is in a state that follows IPC 1.5 inch drain meets the code on a shower.
Old 07-24-2013, 07:06 AM   #8
Only if he's under the 2007 version or newer.
Old 07-24-2013, 06:31 PM   #9
Thats like 6 years old...
In truth a single shower head will not overpower a 1.5 inch drain.
The Following User Says Thank You to Ghostmaker For This Useful Post:
ben's plumbing (07-26-2013)
Old 07-25-2013, 08:06 AM   #10
Well, every jurisdiction doesn't instantly adopt new code versions. When I built my house three years ago, the applicable code was still IRC 2003.
I suspect the change in drain size is related to the almost universal requirement now for low-flow shower heads.
Old 07-25-2013, 06:21 PM   #11
I guess that explains why Ohio and WV do not share license for plumbing...
Old 07-26-2013, 07:58 AM   #12
There are a lot of things WV doesn't share. I used to be a police officer in another state. When we moved to WV in 1999, I looked into a part-time job with the local department. Most states will accept LEO certification from another state, but not WV. For a part-time, maybe $15 an hour job, I'd have to first pay my own way through their 34-week police academy. Since I was already over 50, I didn't see that as something I really wanted to do. Once was enough LOL.
Old 07-26-2013, 05:11 PM   #13
Can't blame you there. I went in the USN at 26 boot camp damn near killed me.
Old 07-26-2013, 05:24 PM   #14
Really? I joined the Navy at 19 in 1967, and boot camp wasn't all that tough. ET school and Nuclear Power School were a ***** though.
Old 07-26-2013, 07:24 PM   #15
I was a surface ET my what a small world..
The running was tuff. Plumbing had lots of ditch digging but no running involved not to mention 13 years of smoking did not help...
Connecting shower drain to toilet drain Liv Plumbing 10 04-17-2013 10:53 PM
Zep Drain Care for larger drains? Ultrarunner2017 Plumbing 13 01-10-2013 09:51 AM
Rusted and almost gone drain pan, Package unit Nordyne kilosos2 HVAC 3 11-18-2012 09:24 AM
Help fixing a leak and installing a drain trap. papageek Plumbing 0 12-01-2010 11:23 AM
Installing Cove Base countrylife Flooring 3 11-19-2006 12:41 PM
