Installing The Drain For A Plastic Bath Tub - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-09-2012, 11:56 PM   #1
installing the drain for a plastic bath tub
I am hooking up the drain for a new plastic bath tub. Do I have to put any silicon on the inside surface before screw in the drain piece? If yes, what kind of silicon? (I am using PVC piping).
sonnyh is offline   Reply With Quote
Old 07-10-2012, 12:00 AM   #2
Rewards Points: 12,876
There should have been a flat rubber washer that came with the drain that goes on the inside of the tub under the drain.
sonnyh (07-10-2012)
Old 07-10-2012, 10:09 AM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
I've never seen a flat rubber washer go on the inside of a tub. . . . .
I always use plumber's putty inside of the tub, and the rubber washer goes underneath.
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
VIPlumber (07-10-2012)
How do you seal plastic overflow drain hole on bathroom sink? stouto Plumbing 13 05-10-2016 11:01 AM
What kind of bath tub drain is this? *pics* ruggar Plumbing 3 10-02-2009 02:08 PM
advice in removing plastic drain valve from water heater darsunt Plumbing 1 06-15-2009 05:30 PM
Installing stand-up shower in finished basement without existing drain notenoughtime Plumbing 3 05-16-2009 12:59 PM
Where to find 2" square plastic drain pipes The_Flash Roofing/Siding 4 07-25-2005 08:35 AM
