Old 05-21-2005, 08:10 PM   #1
Installing diswasher
What are the basics for putting a dishwasher in. I will need to remove some drawers but have the space under the kitchen counter. Is it just as easy as running hot water and electricity to it as well as a waste pipe?
Rich
Remodeling is offline   Reply With Quote
Old 05-21-2005, 09:43 PM   #2
Remodeler
MinConst's Avatar
Yes,
I would use a GFCI protected circuit. The waste pipe is a hose that runs into your existing sink drain into a Y. Most will heat the water for you so cold is all that is needed. Level, and solid and it will run quieter and stable.
Minichillo's Construction
I will never leave you hanging!
MinConst is offline   Reply With Quote
Old 05-22-2005, 01:10 AM   #3
Long-Time DIYer
Mike Swearingen's Avatar
Check with your Building Inspection Department for local code and inspection and permit requirements for a dishwasher. Most usually call for a dedicated dw electrical circuit and an air gap.
It should have a dedicated 110v electrical circuit outlet (usually best put behind it). It normally doesn't have to be on a GFCI. If it ever trips a GFCI, and it's installed behind it instead of under the sink, you'll have to remove the dw from the cabinet to get to it to re-set it. The breaker should trip anyway if there's a problem.
If you're going to have to run a new circuit, I would run it off a 20 amp breaker with 12/2-with-ground wiring in case someone ever wanted to put in a heavy-duty dw. (Code and dw manufacturers usually just call for 15 amp with 14/2wg wire circuit.)
If you don't have a disposal with dw connection, you will have to install a new tailpiece with a dw "Y", preferably under the nearest side of the kitchen sink, for the drain hose connection. Loop the drain hose over the dw, either directly to the "Y" or above-the-sink air gap and then to the "Y" if an air gap is required.
If you have a disposal with a dw connection, don't forget to use a hammer and screwdriver to remove the plastic knock-out plug down in the disposal dw pipe before attaching the drain hose.
Check the particular dw for water connection instructions. Cold is O.K. on most new ones, but I always just connect mine to the hot water line. Whichever, use a separate dw water shut-off valve off of a "T" in the line to connect the dw supply line (may need to buy the supply line separately).
If you're ever planning on adding tile or a wood floor in the kitchen, now is a good time raise the cabinet base (shim up at least the thickness of the tile or flooring). If you install a dw in a cabinet base sitting on vinyl flooring and later someone adds tile for instance, it will trap the dw under the cabinet.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 05-22-2005, 01:48 PM   #4
Thanks for the info guys, that is about what I thought. My only hang-up is the dedicated circut, was hoping that it would be okay to tie into the kitchen wiring.
Rich
Installing a Shower Blaze25 Plumbing 2 10-13-2008 08:32 PM
Installing Quarter Round shanmon Flooring 4 07-19-2007 01:59 PM
Installing Windows after Drywall??? jeepwillies Building & Construction 9 11-22-2006 11:30 AM
Installing a ceiling light fixture? DK75 Electrical 7 02-27-2006 09:10 AM
Installing Corner Countertops on a corner that is not square? tjandt Remodeling 10 12-30-2005 11:26 PM
