Installing Corner Shower On Studs? - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-25-2009, 01:07 AM   #1
Professional Wood Shafter
ryanh's Avatar
Rewards Points: 154
Installing corner shower on studs?
Hello.
The manual for my a corner neo angle shower i bought says to install the base right onto the studs and not over any drywall. I was always under the assumption you drywall the back with humidex/aquaboard drywall.. So i guess they want the drywall to start 5" up or so to attach the shower surround.. but why not behind the base?
ryanh is offline   Reply With Quote
Old 09-25-2009, 07:18 AM   #2
Follow manufacturers recommendations, but the wall should have a moisture barrier, and if an outside wall should be insulated.
Old 09-28-2009, 10:09 PM   #3
the only time i see drywall installed behind a shower is when there is a fire rating for that particular room. Meaning in an apartment or condo the back wall is connected to a hallway or is the median wall between two units otherwise i think its really not need
fhrace is offline   Reply With Quote
Old 09-29-2009, 11:28 AM   #4
i just removed my old fiberglass shower/tub unit. it was installed directly on the studs. the drywall butted up against it to cover the mounting flange.
djrussell is offline   Reply With Quote
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 01:39 PM
Installing Basement Studs jacads Building & Construction 10 03-12-2009 10:25 AM
Corner Shelves for Shower pgb1949 Remodeling 1 02-06-2009 08:11 AM
installing multiple shower heads jimmy21 Plumbing 5 07-02-2008 09:46 AM
Installing a one piece shower... plumbing issues singforsupper Plumbing 2 06-01-2005 09:26 AM
