-   -   Installing corner shower on studs? (http://www.diychatroom.com/f7/installing-corner-shower-studs-53750/)
ryanh 09-25-2009 01:07 AM
Hello.
The manual for my a corner neo angle shower i bought says to install the base right onto the studs and not over any drywall. I was always under the assumption you drywall the back with humidex/aquaboard drywall.. So i guess they want the drywall to start 5" up or so to attach the shower surround.. but why not behind the base?
Just Bill 09-25-2009 07:18 AM
Follow manufacturers recommendations, but the wall should have a moisture barrier, and if an outside wall should be insulated.
fhrace 09-28-2009 10:09 PM
the only time i see drywall installed behind a shower is when there is a fire rating for that particular room. Meaning in an apartment or condo the back wall is connected to a hallway or is the median wall between two units otherwise i think its really not need
djrussell 09-29-2009 11:28 AM
i just removed my old fiberglass shower/tub unit. it was installed directly on the studs. the drywall butted up against it to cover the mounting flange.
