Installing A Corner Shower Stall - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-20-2010, 07:06 PM   #1
Installing a corner shower stall
I am installing a corner shower stall (neo-angle door), my base is very slightly off level, how should I fix this? Or can I ignore this?
Also, my base doesn't meet the walls (there is about 1/2 inch between the drywall that is already there and the base) can I put pieces of wood in there to frame the corner instead of moving the base and all the plumbing?
Can I drill screws into the vinyl sides that are supposed to be glued to the wall as well as use adhesive on the pieces of wood that I will put up?
Does the vinyl sides cover the inside of the base?
Thank you for your help!!
hurley2010 is offline   Reply With Quote
Old 12-20-2010, 10:59 PM   #2
Rewards Points: 266
The base should be as level as you can make it. The suround walls have to completely overlap the base flange. The walls should be furred out to meet the base. If you have the adhesive type walls, the proper way to do this would be to tear out the old drywall and fur out your wall studs. It usually works best to sister boards alongside the existing studs out to meet your new wall requirements. Then you will need to reinstall new drywall or preferably backer board. The direct-to-stud walls for this type of shower would save you the step of reinstalling new wall material.
Any holes you put in the shower wall need to be sealed with silicone caulk.
I had to fur out the back wall of my tub surround. Refer to the pictures to see how I reconciled it to the existing wall. and here is a link to the project to give you more details Jim's downstairs bathroom project .
I considered one of those neo angle showers but did not have quite enough wall space without moving the window. Glad I opted for the tub as it turns out.
Installing a corner shower stall-2010nov21_2.jpg   Installing a corner shower stall-2010nov21_3.jpg   Installing a corner shower stall-2010dec7_3.jpg
Jim F is offline   Reply With Quote
Tags
corner shower stall
Solar Tube in Shower Stall? cbzdel General DIY Discussions 3 05-31-2010 09:21 PM
cracking corner of newly tiled shower stall jmuamy General DIY Discussions 10 04-14-2009 09:38 AM
shower stall with hole (cold air coming in) mcvane Plumbing 1 02-08-2009 11:41 PM
Installing Corner Countertops on a corner that is not square? tjandt Remodeling 10 12-30-2005 11:26 PM
Installing a one piece shower... plumbing issues singforsupper Plumbing 2 06-01-2005 09:26 AM
