Installing Compression Valves - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-11-2005, 06:58 PM   #1
installing compression valves
I am installing compression valves and wall flanges on 1/2" copper (for sink & toilet supply). For some reason I am having trouble making sense the sizes available. I bought a flange for 1/2 copper and it is too small. Not sure if I bought the right thing.... is 1/2 nominal copper correct? I'm confused...
markymark is offline   Reply With Quote
Old 08-11-2005, 08:23 PM   #2
MinConst's Avatar
1/2" is a standard size. There are two type of 1/2" copper Type M and type L. I have allways gotte them mixed up the difference is in the wall thickness. Also the thicker one (I think is the type L) is harder to fit compression fittings and all 1/2" fittings for that matter. But they will fit if no burs are present. If the compression ring is really to small you must have the wrong size.
Minichillo's Construction
I will never leave you hanging!
One Man Shops
MinConst is offline   Reply With Quote
Old 08-11-2005, 10:03 PM   #3
Plumbing pipes are measured by ID (inside diameter) which means 1/2" copper is actually 5/8" OD(outside diameter). This is why your'e flange did not fit, you need 5/8" escutcheon and 5/8" compression valves.
As far as the difference between the types of copper L,M,K, the OD is not effected by the extra thickness only the ID. M is thin wall and L is thick wall and most common for potable water piping and type K is usually soft roll which is the thickest.
plumguy is offline   Reply With Quote
Removing compression ring? ruzz Plumbing 30 10-01-2011 06:14 PM
Installing Quarter Round shanmon Flooring 4 07-19-2007 12:59 PM
Installing a tankless water heater ? bdalekid Plumbing 3 02-26-2007 07:26 PM
compression valve farrington135 Plumbing 6 04-24-2006 01:38 PM
Pressure Compensating Shower Valves MikeinBurien Plumbing 4 12-21-2005 10:13 PM
