Installing A Bathtub - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-09-2011, 11:56 AM   #1
Rewards Points: 107
installing a bathtub
Hey all.
First bathtub install here.
I have a room that's 62 inches wide. The tub will go at the end of room, and I have built out the rough in to be 60 inches wide to match the tub.
Problem. I can't find any way to get the tub to turn around in the room to get it into the space. I can get the tub vertical, but I can't quite get it horizontal. As I'm turning it horizontal, the edges of the apron catch on the walls.
I just re-floored this room, so there is nothing in the room at all except for pex pipes coming up through the floor. It seems like I should be able to work it into place, but no luck so far.
Anybody know the trick?
Thanks.
wengang1 is offline   Reply With Quote
Old 11-10-2011, 08:06 PM   #2
Sorry to be the bearer of bad news but you are going to be doing some demo.
If you have ever seen a new house under construction the tub is put in before all the interior walls are done just because of the issue you are having.
If you are lucky you can just remove some dry wall and the tub will go in with that extra 3 1/2" of space you picked up between some studs. If that doesn't work and your studs are 24" on center on a non load bearing wall you can cut out the bottom part of one stud tub height and slide it in thru the wall. 16" on center and you may have to take out the bottom of two studs.
HalfHand is offline   Reply With Quote
Old 11-11-2011, 10:39 AM   #3
AlbacoreShuffle's Avatar
You haven't lived until you try that with a 400lb cast iron tub. Good times !
AlbacoreShuffle is offline   Reply With Quote
Old 11-11-2011, 11:08 AM   #4
DIY staff
Rewards Points: 7,174
If the drywall is gone the tub apron will clear the studs---
Old 11-15-2011, 12:23 PM   #5
Rewards Points: 107
Thanks all for the replies.
Oh'mike you were right.
I stripped the walls and got it installed.
I did have to shave a stud with the reciprocating saw. It was sticking out a tad.
Installing bathtub on top of tile tvanharp Kitchen & Bath Remodeling 7 03-14-2011 08:43 AM
installing bathtub lupinfarm Plumbing 17 12-11-2010 09:40 PM
Installing bathtub Tudy Kitchen & Bath Remodeling 11 10-19-2010 07:55 PM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 11:42 AM
Refinishing bathtub or installing new one? gante General DIY Discussions 7 06-23-2008 03:54 PM
