Installing Bathroom Sink - Drains Off Slightly Less Than Pipe Diameter - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-14-2010, 11:05 AM   #16
Rewards Points: 1,568
http://www.plumbingsupply.com/images...ght-chrome.jpg
Just cut the pipe; hacksaw should do it; try to keep the cut straight.
bob22 is online now   Reply With Quote
Old 05-20-2010, 09:49 PM   #17
Rewards Points: 152
The Fernco Flexible trap seems to be working. It does say on the package it is safe to use with typical bathroom chemicals. I don't use chemicals, however (package also says most stoppages within the trap can be solved simply by squeezing the trap, although I'd remove trap & clean out rather than risk simply pushing the problem further downstream). At $4/trap (plus $4.50 shipping), you could easily replace this thing every 10 years if you were nervous about any potential for leaks. The biggest danger, I think, is pushing things in the vanity underneath up against the trap & causing some kind of problem.
lazzlazz is offline   Reply With Quote
Old 05-21-2010, 06:12 PM   #18
Leak Master
Nothing like an S-trap to give you that warm fuzzy feeling.
O'Leaky is offline   Reply With Quote
Did I ruin toilet/vent after installing sink??? nibeck Plumbing 4 09-06-2012 08:07 AM
Bathroom Sink Drain (Broken from wall to Ground) bli182nk Plumbing 2 01-11-2009 08:52 PM
Leaking kitchen sink drain pipe zasior Plumbing 10 01-11-2009 08:22 PM
New drains under the basement floor, guidance needed mason Plumbing 6 01-10-2009 05:58 PM
installing vessel sink drain?! (HELP!) tara Plumbing 2 11-10-2006 01:17 AM
