#1 |
Installing Bathroom in Basement Need Advice
Hello,
I am building a full bathroom in my basement. I have completed the framing. Rough plumbing was completed when the house was built. I installed a peatrap for the shower. I am using a shower basin. I have 3 other pvc pipes coming up from the basement floor. One waste for the toliet and two vents. I assume one vent is for the sink and the other for the shower. I am confused on how to vent the sink. If I use 1 1/2" pvc for the sink waste, do I tie the sink waste into the vent pvc with a Sanitary tee? Can I tie both vent pipes together and run them up to the above bathroom vent pipe? I am going to run the cooper as well. I see there is 3/4" pipe running out the main branch. Do I continue to run 3/4" pipe all the way to the sink, shower, and toliet -- then come down with 1/2" pipe to the shower, toliet, and sink? Also, does it matter where I add the shock absorbers at each fixture? Is there anything else I should know? I appreciate your advice? By the way, I live in the Chicagoland area just in case you needed to know. |
#2 | |
Installing Bathroom in Basement Need AdviceQuote:
As far as the water line goes I usually don't catch more than 3 fixtures on a 1/2 inch line(some codes allow for 6 or 7 on a 1/2 inch line). For example I would run 3/4 inch to the toilet on the cold then reduce to 1/2 inch to catch the shower and vanity and on the hot I would tie into a 3/4 inch line and run 1/2 to both lavi and shower. If you want more volume You can run 3/4 all the way to each fixture but I find that unnecessary unless you have very low water pressure and even then it doesn't help much. The shock absorbers should be behind the wall as close to each fixture as possible. |
#3 |
Plumbing Contractor
The water hammer arrestors (shock absorbers) are usually installed on fixtures with quick closing valves (ie selanoid valves) such as washing machine box, dishwasher, etc. Using them in the bathroom wont hurt though. I'd just put in one set on the shower with an access panel and ball valves for changing them out when the time comes.
As far as the pipes coming out of the floor... One for the toilet, 3 or 4 inch One for the shower vent most likely One for the lavatory drain. You cut this off at the proper elevation, install a sanitary tee for your fixture arm going to your vanity, then the vent comes out of the top of the tee. As Al stated, be sure you are at least 6 inches above the highest fixture served before tying your vents together. Run the vent up to an existing vent and tie it in or run it out the roof on its own. Check to see what size your vent must be at the roof penetration if you are running it out on its own. In Ohio it has to be at least 3" due to frost considerations so...if the vent in the house is smaller it must increase in size 6" before it exits the structure. Last edited by JDC; 05-11-2009 at 08:35 AM. |
#4 | |
Thank you for the information. As far as the rough in, here is what I have: 1) One 4" pipe for the Toliet 2) Two 2" pipe -- I thought both of these were vents 3) One 3", 3 1/2", or 4" pipe for the shower drain. I attached a few pictures of the rough in. I also attached a picture of a vent pipe above or very close to the location of the new bathroom. I assume I can tie al the vents into this pipe. Do you think both of those 2" pipes are vents? If they are, what do you recommend I do for a drain? There is an ejector pump already in place. If you want I can go take a picture of the bathroom frame to show you where the elector pump is located. Thank you |
#5 | |
#6 | |
Al, Thanks. How do I know which 2" pipe is the vent and which is for the sink waste? --jeff |
#7 |
The one on the right is the furthest from toilet rough in so I would say it would be that one, but if that is on the wrong side just use the other one the toilet will still vent so basically either one can be used If I was doing it I would use the one on the right if at all possible.
| Tags |
basement bathroom, sink installation ![]() |
| Display Modes | |
| Drop ceiling in basement bathroom | handyflyer | Remodeling | 23 | 05-26-2009 10:12 PM |
| Effluent pump for basement bathroom | Christopher C | Plumbing | 7 | 04-23-2009 10:35 AM |
| Basement Bathroom Costs | ktulu05 | Remodeling | 15 | 04-20-2009 02:24 PM |
| Circuit advice for finishing basement | Straightgrain | Electrical | 16 | 03-25-2009 10:07 AM |
| basement bathroom heat | ktrehs | HVAC | 3 | 03-12-2007 04:23 PM |
