Installing Baseboard Hot Water Radiator Help - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-02-2009, 03:41 PM   #1
Installing baseboard hot water radiator help
My neighbor has a brand new Buderus natural gas boiler, but only her first floor has radiators on it. I'm sure the boiler is spec'd for at least the entire house.
I have some brand new radiators in my basement and I'd like to help her install them in her upstairs.
I assume in theory this is very simple? Just pop in a T in the basement and extend the pipe upstairs and loop it around, eh? Then run the return tapped into the existing return?
Any advice here? I've become pretty good at sweating joints and running pipes all over the place. Would be cool to get her hooked up.
Thanks.
wombosi is offline   Reply With Quote
Old 02-02-2009, 07:54 PM   #2
I would make it a seperate zone.
Mike Brez is offline   Reply With Quote
Old 02-02-2009, 09:41 PM   #3
thanks. yea, i was thinking that would be wise.
so, just T off the hot coming out of the boiler, put a zone valve on it or something?
should be the valve be wired with a thermostat?
Old 02-03-2009, 06:05 AM   #4
yep
take a picture of what she has and we can help you with what and where. you know what I mean
I put in a Buderos last year and was very impressed with it.
II Weeks is offline   Reply With Quote
Water softener leak - how do I set it to bypass? Cylanth Plumbing 4 07-21-2010 10:24 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 09:09 AM
Hot water baseboard heat. auto air bleeder??? pmracing HVAC 2 11-29-2008 05:30 AM
Removing hot water baseboard heaters. Sandy1000 HVAC 4 11-02-2008 05:41 AM
Using baseboard hot water in a radiant floor?? tpagel HVAC 5 03-10-2008 09:33 AM
