Installing Baseboard On CI Steam System? - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-06-2010, 10:35 PM   #16
Originally Posted by SuperPlumberGuy View Post
Anything west of Worcester may as well be a different country
The check valve can go anywhere in the loop, it does not matter. The water is either moving or its not.
thanks buddy. you've been a big help. (and to the others as well.) feeling a bit more confident about this job, but still have lots of questions.
talk to you later. take care.
wombosi is offline   Reply With Quote
Old 06-07-2010, 03:52 PM   #17
Rewards Points: 1,418
Originally Posted by schmolze View Post
OK. is the flow check mechanically operated? i guess i'm confused as to why the check valve is called for here as opposed to mechanical zone valves.
if both zones had flow valves and one zone called for water, wouldn't both flow valves open up?s.
The check valve keeps cooler water sitting in one of the idle zones from coming out backwards and entering the zone that is calling for heat. This ensures that the zone calling for heat gets newly heated water from the boiler.
The check valve and the circulator pump inhibit but don't completely stop forward flow (gravity flow) of heated water through a zone not calling for heat.
A mechanical, usually electrically powered, flow valve can be installed to stop all flow through a zone not calling for heat but most folks consider this to be too much of an expense.
Old 06-07-2010, 08:04 PM   #18
Licensed Master Plumber
Taco makes a circulator with the flow check built in
Always ask to see your contractors license!
NHMaster is offline   Reply With Quote
Installing baseboard hot water radiator help wombosi Plumbing 3 02-03-2009 06:05 AM
Installing DWV system new construction joebart Plumbing 2 01-29-2009 08:45 AM
Help with bleeding baseboard heat system robinswendy HVAC 1 12-13-2008 05:04 AM
Hot Water Heating System in older house GrannyAnnie HVAC 2 08-31-2008 05:50 AM
Size A/C system properly 70stang HVAC 1 03-26-2006 08:22 PM
