Old 06-13-2007, 08:03 AM   #1
Question
Installing 4" no-hub coupler
I'm looking for some advice on installing 2-4"
no hub couplers on a 4" horizontal cast iron soil pipe? I'm doing a repair that requires adding a pvc fitting. Thanks
wibass is offline   Reply With Quote
Old 06-13-2007, 09:47 AM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Use a fernco coupling, they slip over the pipe so you can position fitting your wanting to add. Then set coupling and tighten.
Fix it right the first time, so you won't have to fix it a 2nd time.
Ron The Plumber is offline   Reply With Quote
Old 06-14-2007, 07:14 AM   #3
RippySkippy's Avatar
Sorry for the hijack....but this is kinda related....
Ron, the other day I was at lowes and they have quite a selection of flexible fittings, long sweep wyes, T's etc. Have you ever used then, do you know if they work well? I don't have a specific application, but I can see where they could be handy in the right situation.
Just wondering...
RippySkippy is offline   Reply With Quote
Old 06-14-2007, 09:07 AM   #4
Journeyman Plumber
Never used them, but there code approved here.
Old 06-14-2007, 08:40 PM   #5
That one Guy's Avatar
Not approved here in Washington
Big rats will chew through them
That one Guy is offline   Reply With Quote
Did I ruin toilet/vent after installing sink??? nibeck Plumbing 4 09-06-2012 08:07 AM
Installing Quarter Round shanmon Flooring 4 07-19-2007 01:59 PM
Installing pre-hung doors ffgus Carpentry 6 03-10-2007 04:58 PM
Installing Marble Threshold Redleg Flooring 3 10-21-2006 06:16 PM
Installing Corner Countertops on a corner that is not square? tjandt Remodeling 10 12-30-2005 11:26 PM
