Installing A 2nd Toilet - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-08-2012, 07:31 AM   #1
installing a 2nd toilet
Hi, we're installing a 2nd toilet in the garage to make an efficiency. Does that toilet also need an air vent, or does it work off of the other toilet in the house?
cgpollari is offline   Reply With Quote
Old 04-08-2012, 08:28 AM   #2
DIY staff
Rewards Points: 7,174
Yes---every toilet needs it own vent--2" minimum vent pipe--
Old 04-08-2012, 08:30 AM   #3
MarginallyQualified
Rewards Points: 2,464
Originally Posted by cgpollari View Post
...installing a 2nd toilet in the garage to make an efficiency.
...does it work off of the other toilet in the house?
How far is this new location from the existing DWV stack?
Old 04-08-2012, 05:53 PM   #4
Rewards Points: 636
irc says no vent needed for toilet since it is self siphoning i am assuming there will be a sink to wash hands and that will have to be vented
http://publicecodes.citation.com/ico...2_9_sec009.htm
edit
i should say there has to be a vent but there is no maximum distance between toilet and vent. so you should be able to use another fixture that is vented to vent toilet
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 04-08-2012, 07:03 PM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 792
But the UPC says it does need a vent within 6ft. So what code will the OP be using for inspection purposes....
Old 04-08-2012, 09:48 PM   #6
Rewards Points: 582
it needs a vent
Installing a new toilet flange - before or after tiling WoodmanFL Plumbing 9 01-21-2012 08:29 PM
How to prepare toilet drain pipe for toilet flange? brett.c.brown Plumbing 11 12-15-2011 07:41 PM
Toilet Only on Drain Line Perry401 Plumbing 1 09-27-2011 01:30 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
installing tile. Toilet against the wall joemcjr Building & Construction 4 02-16-2009 08:49 PM
