Installing 2nd Kitchen Sink - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-27-2008, 10:07 AM   #1
Installing 2nd kitchen sink
I'm about to install a prep sink with disposal unit - 35" countertop & 9" bowl depth. What height should a wall drain line be? It would be easier to send the supply & drain up through the floor. The horizontal 2" drain is approx. 6-8" below the floor & the vent stack is about 12" away. Thanks.
stan 41943 is offline   Reply With Quote
Old 03-27-2008, 12:04 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
I set all KS drains at 17" off the floor.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 03-27-2008, 05:17 PM   #3
Send a message via AIM to Marlin
I set them at 16. So long as you aren't going with an especially deep sink or odd disposal 16 or 17 should be fine.
My measurement of 16 is to the center of the pipe. Rons The Plumbers probably is as well.
Marlin is offline   Reply With Quote
Old 03-27-2008, 06:29 PM   #4
Journeyman Plumber
Yes center of tee or pipe stub. Now a laundry tub I'll set at 14 off the floor to center.
Did I ruin toilet/vent after installing sink??? nibeck Plumbing 4 09-06-2012 07:07 AM
vent stack for kitchen sink Knucklez Plumbing 4 04-02-2008 06:49 PM
Rehabbing a porcelain kitchen sink guenthecat Remodeling 10 12-18-2007 10:10 AM
installing vessel sink drain?! (HELP!) tara Plumbing 2 11-10-2006 12:17 AM
Sink or No Sink in Kitchen Island? Not Sure Plumbing 4 08-29-2006 07:37 PM
