Old 07-20-2007, 04:26 PM   #1
Installed bathroom sink, smell now
I installed a new sink and drain recently. I removed the P drain to fit in the new vanity. About 2 days later I reattached everything. I still have the smell from the drain being open without the P attached. How long should/would this smell last? Its been about a day and I can still smell it. Just wondering if its possible I did something wrong. Thanks
HuskySkull is offline   Reply With Quote
Old 07-20-2007, 05:12 PM   #2
Your mistake was not plugging the drainpipe while the trap was removed. Sewer gas contains a lot of different things. You will probably need a fan to get rid of the smell. Fabreeze works well also.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Bathroom sink drain sieve satchmo Plumbing 3 06-07-2007 12:28 PM
Adding an additional sink in Bathroom tke402 Plumbing 1 04-26-2007 10:14 PM
bathroom tub and sink semi-clogged bobo Plumbing 2 04-19-2007 12:24 PM
bathroom sink supply line height bluebee1314 Plumbing 2 03-28-2007 06:47 AM
Laminate Flooring - Is It Installed Under Bathroom Cabinets? BDPNA Plumbing 92 02-07-2007 01:02 PM
