Old 11-15-2011, 09:41 AM   #1
Installation of shower stall in basement
I am planning to remodel current powder room (see diagram) to include a shower. Obviously, i need to break up the concrete floor to tie in some drainage pipes.
My questions are; Where is the best location to begin breaking up the floor to find the existing drainage pipes? And how do i determine which way the drainage flows?
Other info;
home was built in early 70's
all drains are ABS
second storey toilet located above basement toilet (aprox)
Thank you for your guidance.
Herbz is offline   Reply With Quote
Old 11-15-2011, 11:27 AM   #2
Other info;
all drains are ABS
sound's like a good plumber can help with that. Now the floor drain has a open pipe don't know what size. If just a shower and that isn't that far away ?? with out a floor plan ??
del schisler is offline   Reply With Quote
The Following User Says Thank You to del schisler For This Useful Post:
Herbz (11-15-2011)
Old 11-15-2011, 12:59 PM   #3
Tileguy
Bud Cline's Avatar
An experienced plumber could apply some supposition to your drain system and work it out for you. If you intend to do this yourself you need to know if the sewer flows to the front or to the rear of your property. Other factors such as vent stacks and additional floor drains location may be helpful also.
In the absence of a plumber...
One thing you could do is to run a steel snake inside the existing floor drain several feet then use a stethoscope to listen to the floor while someone else agitates the snake inside the pipe. You will be able to clearly hear the snake moving inside the pipe and locate a place to open the floor.
Old 11-15-2011, 01:45 PM   #4
I am assuming that the floor drain heads toward the cleanout value where the venting occurs. Also, i will perform your technique at the cleanout valve to further determine the direction and size of drainage pipe (it must head toward the toilet??). thanks.
Tags
basement bathroom, plumbing, shower install
Basement shower filling with water from upstairs sink. twags Plumbing 4 05-23-2011 04:02 PM
caulking shower stall questions, removal, grout sealing etc detyianni Plumbing 0 11-29-2010 10:00 AM
Advice about framing for a shower stall Tooncie Building & Construction 1 08-27-2010 09:54 PM
Basement Shower Remodel Question mdsnj Kitchen & Bath Remodeling 3 02-27-2010 01:16 PM
Stall Shower Renovation Rick Bruner General Discussion 11 01-20-2008 07:34 PM
