Installation Of Gas Tankless Water Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-14-2009, 01:56 PM   #1
installation of gas tankless water heater
I recently bought an Omega gas tankless water heater and no instruction came with the unit. i am wondering if any on this forum has experience with this unit or comparable units that may have advice on how to install?
sam0709 is offline   Reply With Quote
Old 03-14-2009, 11:09 PM   #2
Click on the website below and then go down the left hand side of the page to the "Contact us". You should be able to get the info you need. Good luck.
http://www.omega2000group.com/
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 03-14-2009, 11:40 PM   #3
Depending where you live, local code often requires this be done by licensed plumber with the proper training.
scotty123 is offline   Reply With Quote
Old 03-20-2009, 02:49 PM   #4
The most important thing you do is properly size the gas inlet piping. Starving the unit could lead to permanent damage.
harrybridges is offline   Reply With Quote
Old 04-01-2009, 07:11 PM   #5
31b
sparky
the exhaust too, improper installation could lead to backdraft in the house.
31b is offline   Reply With Quote
Water connections for new water heater diggerdave Plumbing 16 03-16-2009 11:36 AM
tankless or tanked water heater? wombosi HVAC 5 02-11-2009 08:34 AM
tankless water heater installation HiFlyin Plumbing 3 12-03-2008 12:29 AM
Wiring tankless water heater TheBossQ Electrical 4 07-11-2008 01:05 PM
Electric tankless hot water heater former33t Plumbing 2 02-28-2008 12:40 PM
