Install Tub Spout And Shower Arm - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-23-2010, 06:09 PM   #1
install tub spout and shower arm
i have two 3/4" threaded pipes coming out of the tiled wall above a tub, both about 3" long. how can i install tub spout and shower arm on it? i can't seem to find anything that fits.
any ideas?
install tub spout and shower arm-cimg4355.jpg   install tub spout and shower arm-cimg4358.jpg   install tub spout and shower arm-cimg4357.jpg
ninghai is offline   Reply With Quote
Old 01-23-2010, 08:07 PM   #2
Do something
D'Brie's Avatar
any ideas?
close 3/4" nipple with a bell reducer? nice tile work too!
D'Brie is offline   Reply With Quote
Old 01-23-2010, 08:13 PM   #3
firehawkmph's Avatar
Rewards Points: 1,858
Ning,
Unscrew the pipes. They are normally dummies put in by the plumber for the tile person to tile around. A standard shower arm should screw into the top hole. The bottom one can be replaced with a piece of 1/2" copper with a male threaded adapter soldered to it. Then the tubing can be cut to length for a tub snout that is made to slide over with an allen screw holding it on.
Mike Hawkins
firehawkmph is online now   Reply With Quote
Old 01-23-2010, 08:14 PM   #4
Those are only there to ensure that the fittings (in the wall) didn't get covered over when the tiling was done. Just unscrew and remove them.
It's hard to tell by the pictures, but I'm going to say those are probably 1/2" nipples sticking out of the wall (much more common than 3/4"). Pipe sizes are measured by the inside diameter.
For the tub spout, you'll need to replace that steel nipple with a brass nipple of the proper length. For the shower head, you'll replace that steel nipple with a chrome shower arm and flange.
Ishmael is offline   Reply With Quote
Old 01-23-2010, 08:32 PM   #5
THANK YOU!
i almost called my plumber and give him hell (something like "you knew i have 1/2" shower arm and you put in 3/4" pipe!!!???"), and in the process making a fool out of myself.
i will try to uncrew them tomorrow and see what i come up with.
Old 01-23-2010, 08:39 PM   #6
Just make sure you use teflon tape and/or pipe dope on the threads when you install the new stuff.
Old 01-25-2010, 02:35 AM   #7
use both
fhrace is offline   Reply With Quote
Leaking Shower Diverter Spout baby12121 Plumbing 5 09-27-2009 09:43 PM
Preference for installing tub spout? dolvio Plumbing 7 02-11-2009 10:53 PM
shower and tub spout both run when tub is on Jack A. Trades Plumbing 7 07-10-2008 01:29 PM
Shower head not working, having trouble with replacing the tub spout keyser soze Plumbing 26 06-12-2007 07:39 PM
