Install Of Replacement HW Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-12-2007, 03:19 AM   #16
Journeyman Plumber
Ron The Plumber's Avatar
Shut off heater, diconnect the wires on top of heater, once disconnected energize the circuit and test those wires, check and make sure you have 240v comming to the heater, if not it will be your feed from the power panel, could be the circuit breaker.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 01-12-2007, 07:11 AM   #17
I disconnected the wires & tested. There is 120v on each leg (white & black wire). Tested by placing probes on black & ground, then white & ground. This should be correct. Heater has had power throughout the night & the water seems colder rather than hotter.
I wonder if I bought a cold water cooler??? lol
DIY In King George is offline   Reply With Quote
Old 01-12-2007, 08:32 AM   #18
Journeyman Plumber
If your tester can read ohms, do a ohm test on the elements, you should get a reading from 9 to 14 on the scale, test with wires diconnected from elements
Old 01-12-2007, 08:42 AM   #19
I don't know what I did, but I have warmer water. I think there may have been a bad connection in one of the wire connectors. That is the only thing that I touched today. I am not touching another thing.
I really appreciate all of your help Ron.
Old 01-12-2007, 08:49 AM   #20
Journeyman Plumber
That would do it also, if 240 does not get to the elements they will not heat-up.
York gas heater control board replacement spyvan HVAC 5 12-29-2008 08:12 AM
Chimney Liner for Water Heater mruggeri001 HVAC 6 01-10-2007 07:08 AM
Water Heater - replacement info. CJP Appliances 1 11-17-2006 04:14 PM
Baseboard heater Help! jweinstock Electrical 6 10-28-2006 05:01 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
