Install Plumbing System To The Floor - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-11-2010, 11:37 AM   #1
Rewards Points: 150
Install Plumbing system to the floor
My old house has 1 ground and 1 floor, and the plumbing system is only in the ground. Now I intend to get some plants on the floor, and the problem is water. I wanna changing my plumping system, so that I can get water for the floor.
But I don't know what I have to???
MagicalHome is offline   Reply With Quote
Old 05-11-2010, 11:59 AM   #2
You totally lost me. What are you referring to when you say "ground" and "floor"? A better explanation would help a bunch.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 05-12-2010, 09:51 AM   #3
Rewards Points: 150
Ah, I think it's better to say that my home has 2 floors, the first and the second floor?
Old 05-12-2010, 10:02 AM   #4
Thank you for explaining that. It will be a lot of work to extend all of the Plumbing (water and drainage) to the second floor. You are talking tearing out walls and also the flooring on the second floor.
Old 05-13-2010, 10:22 AM   #5
Rewards Points: 150
According to your saying, it seems hard to be done by myself
Old 05-13-2010, 02:09 PM   #6
Yes, it is a lot of work. You could run the upstairs plumbing while still keeping the lower level intact. Then you could make tie-ins later. Still, cutting walls and floors/ceilings is not pleasurable work.
Rough in plumbing backs up to floor drain rss021815 Plumbing 2 01-03-2010 01:49 AM
I want to install laminate plank flooring but have problem with sub floor In the Bush Flooring 3 04-29-2009 12:35 PM
Varathane Floor Harwood Floor Refinishing System diywic General DIY Discussions 3 08-20-2008 07:36 AM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 07:32 AM
leveling floor 2" for tile install! matty Flooring 2 08-04-2007 01:15 PM
