Install Kohler Shower Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-15-2012, 12:51 PM   #1
Install Kohler shower valve
Wall torn out to studs. Advise best way to mount shower valve. Copper through floor. Can we use PVC?
jaguarcat is offline   Reply With Quote
Old 02-15-2012, 01:00 PM   #2
DIY staff
Rewards Points: 7,174
Why switch to pvc? It will use 2 sticks of copper --and give you a more solid install---
One of the plumbers from an area that allows different pipes will be along soon---
Here copper is code and I have no experience with the alternate piping--
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
ben's plumbing (02-15-2012), jaguarcat (02-15-2012)
Old 02-15-2012, 01:19 PM   #3
Appears we should stick with copper, don't currently have the tools but will gettem.
Thanks!!
Old 02-15-2012, 02:34 PM   #4
fan of brevity I see
broox is offline   Reply With Quote
Old 02-15-2012, 03:37 PM   #5
Broox, brief at this point is better than long winded. I'm a female helper in this project and need more input from my boss, which is hard to get from him. Working on it.
Old 02-15-2012, 05:04 PM   #6
DIY staff
Torch--red tin of flux---plumbing solder and a good tubing cutter---those are the tools---
Plastic will be cheaper---I'm just not knowledgeable in those things--still might need the copper supplies for the conversion to plastic---Mike---
Old 02-15-2012, 05:08 PM   #7
Thanks, its better to go better than cheaper, I'll pass it to my boss.
Located in Las Vegas NV.
Old 02-15-2012, 05:15 PM   #8
DIY staff
Nevada probably allows for plastic pipe---let's see what a plumber says that knows about non copper piping---I live in a very restrictive part of the country---
Old 02-15-2012, 07:49 PM   #9
Rewards Points: 636
mike does kane county follows Illinois plumbing code
jaydevries is offline   Reply With Quote
Old 02-15-2012, 08:00 PM   #10
Rewards Points: 13,712
PVC would not be used in a water pressure line.
Go with copper, Pex, or CPVC if codes allow.
Far better to go with all copper since that's what's already there
Old 02-15-2012, 08:09 PM   #11
Thanks a bunch Mike!
Old 02-15-2012, 08:41 PM   #12
Rewards Points: 582
go with copper piping for support....
The Following User Says Thank You to ben's plumbing For This Useful Post:
jaguarcat (02-24-2012)
Old 02-16-2012, 12:13 AM   #13
DIY staff
I work in DuPage and Cook county mainly---Most towns follow Chicago code--Copper only--type L---no Romex wiring--conduit only--
Kane county allows Romex but it's rarely used---
Old 02-16-2012, 12:49 AM   #14
Rewards Points: 636
mike you are talking commercial ?
Old 02-16-2012, 09:00 AM   #15
Doing it myself
Alan's Avatar
Rewards Points: 2,086
PVC shall not be used inside of buildings or within 2 feet of structures.
Journeyman Plumber
Tags
install , shower , valve kohler
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 04:19 PM
Delta Jetted Shower - install problems . . . Eusibius2 Plumbing 7 11-12-2009 11:21 PM
How to install thermostatic reactive valve and repack supply valve Leah Frances How To Guides 1 06-10-2009 10:49 AM
Resource for understanding gas valve? darsunt HVAC 19 02-03-2009 11:08 PM
Do the fittings need to be sweated before being installed on shower valve? twilightcall Plumbing 5 08-24-2008 11:47 PM
