-   -   Install Kohler shower valve (http://www.diychatroom.com/f7/install-kohler-shower-valve-133830/)
jaguarcat 02-15-2012 01:51 PM
Wall torn out to studs. Advise best way to mount shower valve. Copper through floor. Can we use PVC?
oh'mike 02-15-2012 02:00 PM
Why switch to pvc? It will use 2 sticks of copper --and give you a more solid install---
One of the plumbers from an area that allows different pipes will be along soon---
Here copper is code and I have no experience with the alternate piping--
jaguarcat 02-15-2012 02:19 PM
Appears we should stick with copper, don't currently have the tools but will gettem.
Thanks!!
broox 02-15-2012 03:34 PM
fan of brevity I see
jaguarcat 02-15-2012 04:37 PM
Broox, brief at this point is better than long winded. I'm a female helper in this project and need more input from my boss, which is hard to get from him. Working on it.
oh'mike 02-15-2012 06:04 PM
Torch--red tin of flux---plumbing solder and a good tubing cutter---those are the tools---
Plastic will be cheaper---I'm just not knowledgeable in those things--still might need the copper supplies for the conversion to plastic---Mike---
jaguarcat 02-15-2012 06:08 PM
Thanks, its better to go better than cheaper, I'll pass it to my boss.
Located in Las Vegas NV.
oh'mike 02-15-2012 06:15 PM
Nevada probably allows for plastic pipe---let's see what a plumber says that knows about non copper piping---I live in a very restrictive part of the country---
jaydevries 02-15-2012 08:49 PM
mike does kane county follows Illinois plumbing code
joecaption 02-15-2012 09:00 PM
PVC would not be used in a water pressure line.
Go with copper, Pex, or CPVC if codes allow.
Far better to go with all copper since that's what's already there
jaguarcat 02-15-2012 09:09 PM
Thanks a bunch Mike!
ben's plumbing 02-15-2012 09:41 PM
go with copper piping for support....:yes:
oh'mike 02-16-2012 01:13 AM
I work in DuPage and Cook county mainly---Most towns follow Chicago code--Copper only--type L---no Romex wiring--conduit only--
Kane county allows Romex but it's rarely used---
jaydevries 02-16-2012 01:49 AM
mike you are talking commercial ?
Alan 02-16-2012 10:00 AM
PVC shall not be used inside of buildings or within 2 feet of structures.
