Install Heights For Shower Fixtures - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-20-2010, 01:28 PM   #1
Rewards Points: 270
install heights for shower fixtures
I am installing a shower enclosure (no tub) and a new shower head system. Probably something like this (maybe different brand but same style).
http://www.faucetdepot.com/prod/Amer...rome-92434.asp
Is a standard shower valve just a tub valve with a cap / plug on the bottom port (what would otherwise be the tub feed)? Or is there a special valve made for shower enclosures only?
Also wondering if there are "typical" or standard heights for roughing in / mounting all the shower fixture parts in the enclosure (the valve, riser / wall supply, and also how high to install the bar for the adjustable shower head to clamp on to.
I suppose the mfg would include some directions / recommendations - even so, from an aesthetic point of view, what do you all typically do in that regard?
thanks
rtoni is offline   Reply With Quote
Old 10-20-2010, 05:43 PM   #2
Rewards Points: 150
install heights for shower fixtures<<<
You can start with the manufactors recombinations and ajust them to suit yourself.
>>>Is a standard shower valve just a tub valve with a cap / plug on the bottom port (what would otherwise be the tub feed)? Or is there a special valve made for shower enclosures only?<<<
They make them both ways, it you want to use a tub-shower valve you just plug the tub port.
Don't forget to put some wood where the pipes come thru for support.
braindead is offline   Reply With Quote
Old 10-20-2010, 08:49 PM   #3
Rewards Points: 270
thanks braindead - btw great handle - kinda how i feel a couple hundred times in my projects
thanks again
No power to light fixtures or switch in garage mrsirmrman Electrical 5 09-29-2010 03:36 PM
Master Bathroom Fixtures mpt1123 Plumbing 1 03-01-2009 04:08 PM
Replacing Bathroom Light Fixtures, going from one to two. diynewb Electrical 3 11-25-2008 10:16 AM
When to install tile flooring? MT Stringer Remodeling 4 10-28-2008 08:49 PM
Advice on replacing bathroom fixtures t1000 Plumbing 3 07-11-2008 02:42 PM
