Install Gas Stove To Existing Propane Line - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-09-2012, 01:51 PM   #1
install gas stove to existing propane line
Kitchen has hookups for electric AND gas/propane stove. How do I switch from electric to the gas/propane hookup for new gas stove?
Mark86 is offline   Reply With Quote
Old 08-09-2012, 02:31 PM   #2
Rewards Points: 13,456
If there already a shut off valve and a flex line there just connect the gas line.
Just make sure it's set up for the type fuel your using, natural gas or propane.
Instead of a 220 volt line your new one may have just a 110 volt plug to run the clock and timer.
Old 08-09-2012, 04:48 PM   #3
Rewards Points: 1,216
Just jumping in with joe, IMPORTANT the stove you are installing must have the correct fuel.
Natural Gas and Propane are different pressures.
COLDIRON is offline   Reply With Quote
Old 08-09-2012, 07:14 PM   #4
Rewards Points: 582
what gas is supplied to your home...gas or propane......order stove for proper fuel...then no problem with hook up????
Old 08-09-2012, 08:58 PM   #5
Rewards Points: 83
Completely different gases.
If you already have the gas stove, it can always be converted. Orifices and pressures need to be adjusted by somebody who is qualified. Easier to get the right appliance the first time though.
Protocol. is offline   Reply With Quote
Old 08-09-2012, 10:20 PM   #6
We use propane, have it delivered regularly. Thanks for all advice, very helpful.
Old 08-10-2012, 06:26 AM   #7
Rewards Points: 582
great...when you get a stove tell them you need propane....it we already be set up for it..
Old 08-28-2012, 04:20 PM   #8
I want to switch from electric stove to propane stove. The seller of the house said there was hook up for both behind the stove. I removed electric stove and behind it on the wall is a metal box (about 4 x 4 inch) with the plug for the electric stove and also a thick line with a blue plastic end hooked to the side of the metal box (other end runs behind the cabinets). How can I tell it's actually set up for propane? Should I take the front of the metal box off? Thanks.
Old 08-28-2012, 10:37 PM   #9
Could you post a pic of what you have so we can help you figure it out? How to attach a photo to a post
VIPlumber is offline   Reply With Quote
Old 08-28-2012, 11:20 PM   #10
Registered User
Rewards Points: 5,492
Moved you to "Plumbing", Gary
Adding a second line to existing septic line Eddietan Plumbing 3 05-10-2012 09:27 AM
New Panel Install and Stove not working **FYE** Electrical 5 10-19-2011 09:25 PM
Install new vent/register into existing duct work? Jughead HVAC 11 12-09-2010 05:08 PM
Install Flashing onto existing deck ledger, stucco home Ameekins Building & Construction 1 09-15-2010 05:51 PM
Gas Stove Install johnrh Plumbing 3 04-07-2010 06:36 PM
