Install Garden Hose Valve Atop Hot Water Heater? - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-16-2013, 02:33 PM   #16
Rewards Points: 1,310
If that's a pipe thread at the heater inlet, bull head a tee there and re-connect the flex line water in running and garden water out running.
Old 04-16-2013, 05:49 PM   #17
Rewards Points: 1,958
Please add a house vacuum breaker on that.
Old 04-17-2013, 04:11 PM   #18
hammer & DidIDoThat (man, that would be a great name for a stakes horse ), I think you're on to something that could work for me. If it's not hard for me to make a strain relief for the garden hose that would probably also be secured somewhere above the HW heater (so it can't be walked into), maybe the T right on the intake nipple would work. But the other solution is also a possibility.
The bad part of putting a tee straight into the tank is you'd be putting tension on a fitting that's absolutely NOT designed for it.
No argument there, that's why I'm only considering this as a temporary solution until I can get a proper permanent installation. This will not be a no-risk solution but I'll do it if I can make it low-risk.
six50joe is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Turning off hot water to fix 1/2 inch CPVC pipe in crawl space steve3847 Plumbing 21 12-20-2012 01:53 AM
Re-installing saddle valve on newly installed water heater connections bkraz Plumbing 18 12-16-2010 02:51 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
