Install A Dryer Vent - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-04-2010, 10:38 AM   #1
Install a dryer vent
A dryer vent has to be alumiun all the way to the outside
mcd5212 is offline   Reply With Quote
Old 06-04-2010, 03:26 PM   #2
if thats a question the answer is yes
just a guy is offline   Reply With Quote
Old 06-04-2010, 06:26 PM   #3
Rewards Points: 1,088
When people install dryer vents through the roof or gas flues or even vent pipes, do you guys just rely on the flashing or do you guys put down some sort of weathershield layer?
handy man88 is offline   Reply With Quote
Old 06-05-2010, 07:34 AM   #4
Rewards Points: 1,216
Yes.. and make sure the pipes are installed properly in the direction of flow as to not collect lint. Stay away from that flex stuff.
COLDIRON is offline   Reply With Quote
Old 06-05-2010, 07:36 AM   #5
So the flashing itself that comes with the vent is not enough?
Old 06-05-2010, 10:34 PM   #6
We use steel.
fpeftw is offline   Reply With Quote
Old 06-06-2010, 09:09 AM   #7
Household Handyman
Rewards Points: 1,408
I don't like to use the thin aluminum round ducting because it seems to get crushed too often. I have had to place a piece of wood, cut accordingly, for some homeowners whose dryers "mysteriously" move back towards the wall often. Generally I try to use the heavy duty aluminum or galvanized material. Maybe a little harder to install, but last longer. David
Cutting through sill for dryer vent mjkpainting Building & Construction 13 06-05-2012 05:14 PM
Dryer Vent DoubleHumbucker Appliances 3 10-02-2009 01:50 PM
Proper way to install half round dormer vent? Git Roofing/Siding 12 07-31-2009 05:33 PM
very clogged dryer vent. Not just lint catman Tools 4 04-20-2009 04:48 PM
Help/moving dryer vent mjkpainting Plumbing 3 11-13-2008 08:44 AM
