-   -   Install a dryer vent (http://www.diychatroom.com/f7/install-dryer-vent-72802/)
mcd5212 06-04-2010 10:38 AM
A dryer vent has to be alumiun all the way to the outside
just a guy 06-04-2010 03:26 PM
if thats a question the answer is yes
handy man88 06-04-2010 06:26 PM
When people install dryer vents through the roof or gas flues or even vent pipes, do you guys just rely on the flashing or do you guys put down some sort of weathershield layer?
COLDIRON 06-05-2010 07:34 AM
Yes.. and make sure the pipes are installed properly in the direction of flow as to not collect lint. Stay away from that flex stuff.
handy man88 06-05-2010 07:36 AM
So the flashing itself that comes with the vent is not enough?
fpeftw 06-05-2010 10:34 PM
We use steel.
Thurman 06-06-2010 09:09 AM
I don't like to use the thin aluminum round ducting because it seems to get crushed too often. I have had to place a piece of wood, cut accordingly, for some homeowners whose dryers "mysteriously" move back towards the wall often. Generally I try to use the heavy duty aluminum or galvanized material. Maybe a little harder to install, but last longer. David
