Install Clean Out T, Existing PVC, How? - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-08-2011, 01:19 PM   #1
Rewards Points: 49
install clean out T, existing PVC, How?
Hi,
This seems like a stupid question....I am trying to install a "T" or a clean out actually in an existing 3"PVC line coming from the upstairs to the basement and into the septic system.
There is NO "give," or no slop, play, etc., at all in the existing pipe installation...so HOW do I cut out a 9" piece of the exisiting straight pipe and then insert the clean-out piece?
I cut the pipe, insert the new piece, slide it over 1/2" to make the connection...and I'm left with a 1/2" gap on the other side.
Is my only option to use a rubber connector on one end of the clean-out T ?
kree is offline   Reply With Quote
Old 12-08-2011, 01:48 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,252
Use a wye not a tee for the cleanout. Install a short stub of PVC in the top of the wye and connect with a Fernco shielded coupling (a rubber connector as you call it). Any plumbing supply, good hardware or big box store will have them.
Coastal South Carolina
Old 12-08-2011, 01:56 PM   #3
Rewards Points: 175
Hi, It will be a tight fit but you have about 2" if room in fitting so prime both ends then glue up make sure to subtract difference slide up at an angle to get on, then slide it down "so both ends are even" then wrap primer/glue around both HUB x HUB to ensure its air tight.
Licensed Plumber!
plumbing is offline   Reply With Quote
Old 12-08-2011, 02:06 PM   #4
biggles's Avatar
might get a slip coupling and use the cut away pipe to fit the Y clean out
Old 12-08-2011, 06:42 PM   #5
Rewards Points: 49
Like "plumbing" said, if I want a solid PVC connection, then I should be enough room in the ends, like "A"? Is this what I could try?
I'd prefer a solid connection....
Thanks!
Old 12-08-2011, 06:55 PM   #6
Rewards Points: 175
Ok then stick with the rubber coupling with straps
Old 12-08-2011, 06:56 PM   #7
Owner
LateralConcepts's Avatar
What you're looking for is called a repair coupling. Use a WYE for your cleanout, cut two small stubs of pipe to glue in each end so you have enough left over to glue your repair couplings on. They don't have the little rib in the inside center, so you'll be able to primer, glue, then work quickly to slide them in place.
Also, don't listen to what "plumber" mentioned.
then wrap primer/glue around both HUB x HUB to ensure its air tight. "Licensed Plumber"
A licensed plumber wouldn't slop glue all over the hubs to make sure it's air tight.
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
The Following 2 Users Say Thank You to LateralConcepts For This Useful Post:
ben's plumbing (12-08-2011), VIPlumber (12-08-2011)
Old 12-09-2011, 06:55 AM   #8
Rewards Points: 49
I appreciate all suggestions. i googled slip fittings and it seems like many people have issues with them getting stuck halfway thru the installation or a leaky joint?
Is this true?
Any tips to guarantee success?
New cabinets, subfloor & install height Ohming Building & Construction 10 03-02-2011 02:18 PM
Install baseboard over/around existing trim of bathroom vanity? sunshine22 Remodeling 2 02-24-2011 08:39 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
New Roof and Insulation over Existing Roof MitchellScott Roofing/Siding 1 05-03-2009 08:24 AM
natural gas install to existing house sagechickie Building & Construction 9 04-22-2009 09:44 PM
