Install A Check Valve On Cold Line? - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-27-2010, 04:43 PM   #1
Install a check valve on cold line?
I have hot water coming out the cold faucet in my restaurant. I believe I isolated the problem to the pot wash sink - during the day both faucets are left open, and the water is controlled with a sprayer.
Can I fix this by putting a check valve on the cold water side?
If so, is this easy to do (if Im not a plumber)?
Thanks.
JTurkel is offline   Reply With Quote
Old 10-27-2010, 09:01 PM   #2
HVAC / Plumbing
Thanks.
Do you have an expansion tank?? If you stop the expansion the water pressure will have to go somewhere T& P will open
kenmac is offline   Reply With Quote
Old 10-27-2010, 11:22 PM   #3
Plumb or Die!
Check valve will work. Not sure what that exp tank comment was about. The ease of install depends on a lot of things.
plumber666 is offline   Reply With Quote
Old 10-28-2010, 06:47 AM   #4
Just call me Andrew
Rewards Points: 1,020
That's only if you put the check valve between the main and the water heater. He is not doing that.
Andrew
secutanudu is offline   Reply With Quote
Well check valve problem, well question maxalex Plumbing 7 08-21-2016 02:21 AM
can I runa second line from a pre-existing saddle valve? ClancyKev Plumbing 1 10-23-2009 06:02 PM
Very Small leak at Shower Valve on Cold Water Side, Threaded. Tighten it more or ? twilightcall Plumbing 3 08-25-2008 08:19 AM
Does a shower valve need to have both hot and cold connected to work? twilightcall Plumbing 5 08-24-2008 07:00 PM
Leaking pressure relief valve Chris Magee Plumbing 12 08-12-2008 07:48 PM
