Old 07-11-2009, 04:52 PM   #1
toolbelt Tina's Avatar
install -center sink
I am attempting to install my double sink.
The directions were non existent except for a template on the side of the box.
Do I just center it on all sides? (as I was going to do.) Or is the front and back setback a different increment?
thanks
Last edited by toolbelt Tina; 07-11-2009 at 04:54 PM. Reason: hit enter by mistake
toolbelt Tina is offline   Reply With Quote
Old 07-11-2009, 06:21 PM   #2
GC/Master Plumber/Mech
If you use the templet the place it about 1" from the back splash. This will give you about 1/2" of showing countertop from the edge of the sink and back splash. This will also give you about 1" to 1 1/2" chowing countertop from the front edge to the front edge of the sink.
I am assume you are using a self rim stainless sink
Old 07-11-2009, 07:52 PM   #3
Originally Posted by Plumber101 View Post
If you use the templet the place it about 1" from the back splash. This will give you about 1/2" of showing countertop from the ...
Hi thanks for the quick help.
Sorry for my ignorance but I can tell you it is not an undermount sink anything beyond that is beyond me.
Plumbing is not my forte'. I was hooking up my supply lines and the instructions said "hand tighten and 1/4 turn" however I can't hand tighten as well as say a plumber could. So it was a drawn out process tighten... leak observe... tighten leak. And a week later a few drops ...no idea where they are coming from everything appears dry .
utility sink pump? mepeterser2451 Plumbing 3 12-01-2008 11:46 AM
Sink Depth dilemna Yippee Plumbing 9 01-01-2008 01:25 PM
Rehabbing a porcelain kitchen sink guenthecat Remodeling 10 12-18-2007 11:10 AM
Single Sink To Double Sink 39centstamp Plumbing 4 06-24-2007 11:27 AM
Fixing a sink - paint removed from the sink deb14905 Painting 2 04-19-2007 12:26 AM
