Old 12-27-2012, 11:05 AM   #1
install 3/4" solder check valve
Does the flow arrow or the cap point up and do the gaskets need to be removed prior to soldering
Craig1313 is offline   Reply With Quote
Old 12-27-2012, 11:11 AM   #2
The arrow should point in the direction the waters going to be flowing.
Got a picture if the valve your going to use?
Old 12-28-2012, 09:38 AM   #3
Ideally all plastic, rubber, or other non-metal parts should be removed before soldering although often this is not possible. A faucet or hose bibb or in line valve that is soldered (sweated) on should be in the open position.
The advent of lead free solder has increased the chance of damage to valves and other fittings during soldering. Electronic solder, which has a lower melting point, is safer for the valves and fittings although that joint would have a tendency to come apart at the moment another nearby joint was soldered using regular plumbing solder.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
The Following User Says Thank You to AllanJ For This Useful Post:
Craig1313 (12-28-2012)
Backup sump pump & check valve issues Richo Plumbing 7 10-14-2012 09:44 PM
Husky/CH Compressor check valve question EdPDX Tools 7 10-02-2012 05:37 PM
sewage ejector pump check valve ogbill Plumbing 3 04-17-2012 12:28 PM
slamming check valve on basement ejection pump crankcase Plumbing 4 12-04-2011 09:38 PM
Sewage Lid + check valve majorchamp Plumbing 2 07-07-2008 11:06 AM
