Instaling A Exhaust Fan. - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-18-2009, 12:51 AM   #1
Question
instaling a exhaust fan.
I am renovating my new basement and need to install the exhaust fan which I never seen in my life. any help?
raulakh is offline   Reply With Quote
Old 09-18-2009, 05:57 AM   #2
Follow the directions with the fan, usually a good guide. Make sure it is ducted to the outside. Do not just let it exhaust inside a joist bay.
Old 09-18-2009, 01:02 PM   #3
Registered User
Rewards Points: 526
My generic for the ducting: . Use straight pipe (metal or PVC) whenever possible, wrapped with insulation and a vapor barrier. Corrugated, flex pipe creates turbulence and has almost double the surface area for water exhausted from baths to collect on. Use as few bends as possible with 45*s instead of 90*. Tape metal joints with silver tape, not duct tape (4 year life). Tape the individual joints of each elbow. Use 3 screws on each metal joint. Use HVAC black tape for plastic covered insulation. Insulate the whole pipe and the fan box.Use caulk to seal the small gaps at the fan to wallboard joint. Don't drill through any floor joists, rim is OK.
Be safe, Gary
Old 09-19-2009, 09:47 PM   #4
Thanks Gary, It is wonderfull.
HRV Exhaust Duct jweiner HVAC 8 01-20-2009 01:51 PM
Central-vac exhaust curls00 General DIY Discussions 4 03-09-2008 12:28 PM
Can I T my new dryer's exhaust into my bathrooms exhaust? Felipon Appliances 2 01-30-2008 06:53 PM
Complex challenge with bath exhaust fan - need help with solution! Honest Bill Electrical 6 11-02-2007 02:52 PM
Furnace Exhaust To Outdoors celticFC HVAC 1 09-01-2007 01:27 PM
