Instal A New Toilet - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-06-2008, 04:11 PM   #1
Instal A New Toilet
I Need To Replace A Toilet In My Father In Laws House.
I Am Used To Pvc Pipes But He Has Cast Iron. How Much Of A Difference Is There And Are There Any Special Things That I Need To Have Or Buy For This Install
JAVAMAN is offline   Reply With Quote
Old 10-06-2008, 05:42 PM   #2
no plumber here, but if you're just changing out the toilet it won't matter, now if you have to do repairs on that pipe that is different, otherwise, yank out old one, use new wax ring and place new toilet in place. If I'm missing something, it will come to me later.
DUDE! is offline   Reply With Quote
Old 10-06-2008, 08:25 PM   #3
Should not be any problem. Just purchase a new wax seal and bolts. The orientation is the same as PVC but just a different material.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 10-06-2008, 09:59 PM   #4
Rewards Points: 562
Your water supply MAY be more challenging than the drain. does it have a shut off? The braided hoses are nice or vinyl tubing if straight.(it kinks if trying to make too quick of right angle turn)
4just1don is offline   Reply With Quote
Old 10-06-2008, 11:29 PM   #5
Week End Warrior
Frank Steele's Avatar
If the flange is not cracked or broken you will be fine. Install it the same way as if it was a pvc flange with a bowl wax
Frank Steele is offline   Reply With Quote
Old 10-07-2008, 08:43 AM   #6
THANKS EVERYONE FOR ALL THE REPLIES. I FIGURED THAT THERE WOULDN'T BE MUCH DIFFERENCE BETWEEN PVC AND CAST IRON. jUST WANTED TO MAKE SURE SO I HAVE ALL THE RIGHT STUFF TO GET THE JOB DONE RIGHT. THANKS AGAIN
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Advice on commercial toilet install SoCalSwami Plumbing 9 05-15-2008 04:43 PM
Need opinion - Need help - I believe my toilet was not installed properly rdlegacy Plumbing 9 05-06-2008 06:03 PM
why one toilet backs up and other does not Richmarti12 Plumbing 2 03-16-2008 03:22 AM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 07:33 PM
