-   -   Inside Pipe Cutter (http://www.diychatroom.com/f7/inside-pipe-cutter-7748/)
amakarevic 04-12-2007 12:16 PM
Inside Pipe Cutter
i bought the following product to do some inside ABS pipe cutting:
http://www.amazon.com/Plumb-Shop-Ins...6397802&sr=8-1
the problem with it was that the blad is fastened to the shaft with a screw, which caused it to unscrew when the drill was spinning in the corresponding direction, which caused me to lose the screw as i was cutting a vertically-positioned toilet pipe rooted in the basement concrete of my house.
later on, it occurred to me that perhaps, i should have been spinning the drill in the opposite direction, which would have the opposite effect - fasten the screw even tighter. but that was after the fact.
nevertheless, i think it is a STUPID DESIGN of the cutter - the two pieces should have been welded rather than screwed to enable motion in each direction.
the product also never came with any instructions/manual to explicitly warn of the proper direction usage.
i was wondering if there is an alternative product that meets my design vision above (welded pieces) or simply a better product someone would recommend ?
thanks,
- a
KUIPORNG 04-12-2007 01:55 PM
I did inside cutting toilet drain pipe with regular rotery tool with cutting wheel... it did the job... I agree with you regarding the problemtic direction.... they also sell similar cutting wheel for rotery tool... although the one I used is not the same... I also attached the wheel to drywall rotary cutter which also work better but it has limited depth access......
