Old 11-29-2012, 09:44 PM   #1
inserting copper fittings very difficult
After i cut and sandpipe the end of the 3/4 copper pipe,
Its really difficult to insert the pipe and fitting together.
They bind.
Without sanding the pipe and fittings they come together OK but thats not the way ur supposed to do it.
Can i use a smoother sand paper?
If you just flux the pipe and fitting and turn them around a bit would that work?
Any suggestions? thx!!
Does these fittings need to be supper clean or can they just be touched with the sand paper. I purchased the oatey sandpaper.
john_bry is offline   Reply With Quote
Old 11-29-2012, 09:54 PM   #2
Fitting and pipe both have to be clean or the solders not going to stick.
I use one of these instead of sandpaper.
http://www.bing.com/images/search?q=...A15C40&first=1
Old 11-29-2012, 10:04 PM   #3
They bind.
sometimes the cutting wheel on tubing cutter leaves a small ridge ...thats tells you its time for new wheel....other reason is inported fittings.. ben sr
The Following User Says Thank You to ben's plumbing For This Useful Post:
oh'mike (11-30-2012)
Old 11-29-2012, 10:59 PM   #4
Doing it myself
Alan's Avatar
I had a fitting like that the other day. Usually with a small amount of banging I can get them to go together even if they're tight, but I ended up deforming it quite badly, so I threw it across the crawlspace in disgust.
Journeyman Plumber
Alan is online now   Reply With Quote
Old 11-29-2012, 11:17 PM   #5
Water Treatment
And what is the price of copper today?
There is shinny and then there is dirty... either way it adds up to hold on to for the scrap buyer.
Akpsdvan is offline   Reply With Quote
Old 11-30-2012, 08:40 AM   #6
joed's Avatar
How are you cutting the pipe? If you are using a saw then you are deforming the pipe. Use a tubing cutter.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 11-30-2012, 08:45 AM   #7
Super Moderator
Yep==Need a sharp cutter----use a file to remove the burr---then get a sharp tubing cutter---
Copper to Pex and Using "Gator Bite" Fittings? jdm001 Plumbing 5 12-21-2011 11:23 AM
i want to move my a/c about 4 feet from the house, can i run the copper fittings that far or will it effect the ac performance? monello HVAC 3 04-11-2011 05:37 AM
Replacing 2" Copper Mike Mike Plumbing 1 03-23-2011 03:11 PM
Copper or PEX (and which PEX connectors) SFX Group Plumbing 3 11-03-2010 09:06 AM
Anyone using Ridgid Propress & press fittings? -For Copper NOT PEX- ChrisDIY Plumbing 2 03-30-2010 10:38 AM
