Inline 1 1/2" Pump? - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-14-2015, 09:29 PM   #1
First Home N00b
Rewards Points: 162
inline 1 1/2" pump?
cliffnotes: does anyone make a low maintenance inline pump for 1.5" PVC schedule 40 pump that is reasonably quiet and can pump a sink drain upstream no more than an inch over a 25ft span?
Long version - I purchased a home with a 3ft (at the best parts) crawlspace and I am a 6' 5" guy with mild OCD. In such space there is flexible HVAC draped like Christmas lights from the 2x8s, the knob and tube wiring mixed in with the modern and armored none of which seeming to make any sense as to direction or organization, and plumbing which seems to conform to the rules of inadequate support, nonsensical direction or organization, and roughly 1.5 foot of height, as in the way as possible.
I have been doing my best to relocate all of these up between the joists, and where not possible across them to create as much workspace as possible. The kitchen sink provides the final great challenge - 1.5" PVC SCH40 about a 25 to 30 foot run from the sink to the main septic 3" vertical drain...currently conveniently installed at exactly half the height of the crawlspace to inhibit work as much as absolutely possible - I would like to relocate this one as well up between the joists but a few small sections would require a run parallel to the joists - over the span, the best I can estimate is at least no rise but maximum of 1" rise.
From the sink to where I would have to make the first 90 degree bend is roughly 4 feet, so I would assume any drainage by that point would have picked up a bit of potential energy but I am not sure it would continue over that long of a span at best of level.
I was thinking some sort of inline pump would be best. I am open to suggestions. Keep in mind that at some points in this crawlspace it is belly-only so the crappy plumbing changes things from being inconvenient to being totally inaccessible.
95PGTTech is offline   Reply With Quote
Circulator pump: guilty or not guilty? alight9010 HVAC 15 12-28-2015 08:43 PM
Well pump trips breaker at start, but then starts when breaker reset J. David Electrical 34 02-25-2012 11:23 AM
Intermittent submersible pump fault esquilax Electrical 5 09-30-2011 03:56 AM
Shallow well pump issues, spinnb7 Landscaping & Lawn Care 1 04-13-2010 01:04 PM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 06:09 PM
