-   -   Injected too much foam sealer to repair tub, how to remove foam? (http://www.diychatroom.com/f7/injected-too-much-foam-sealer-repair-tub-how-remove-foam-114194/)
amodoko 08-16-2011 02:01 AM
A few months back I was trying to repair my cracked fiberglass tub without having to install a new one. It was severely cracked and needed significant repair. I had paid a professional company $200 about 19 months ago to repair it and it held up for about a year (they just injected foam and sealed it with bondo and put an adhesive mat over it).
Well I tried to repair it myself a few months ago, and I injected too much foam. The good news is it stopped water from leaking under the tub. The bad news is it made the tub all bumpy and uneven since the foam expands once it dries (it's called Great Stuff, sold at most hardware stores).
The tub is leaking again, and I want to try to repair it one more time before installing a new tub. But I want it to cosmetically look nice. Is there any way I can break down (like chemically break down, or something else) the foam that I injected under the tub? If I can break it down, then I can get the tub to have a flatter surface, then I can try to do a really good repair job before buying and installing a new tub.
So any way to inject something under the tub to break down "Great Stuff" without damaging the support structures under the tub?
Just Bill 08-16-2011 07:13 AM
The only way I know of is to physically dig it out, but it sounds to me like it is time to replace the tub.
amodoko 08-16-2011 07:28 AM
Yeah, I kind of agree Just Bill. I was hoping that there was something I could do, but I have a feeling I will just have to replace the tub. I don't think it's worth it to dig out the foam. I may just seal it up a bit more so it won't leak, and then I'll replace it next spring or summer
COLDIRON 08-16-2011 07:53 AM
Just manually cutting it out with serrated blade knife.
handy man88 08-16-2011 01:42 PM
I had that stuff stuck on my hands the first time I used it and wasn't smart enough to use gloves.
I tried Goof Off and it kind of smoothed it out.
The only way to get it off your hands really is to peel it off or wait for your skin to shed.
It's nasty stuff.
You can also use a razor blade to cut off big chunks.
