Inground Swimming Pool Pipes Leak When Pump Running.. - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-25-2010, 08:17 PM   #1
inground swimming pool pipes leak when pump running..
2 inch pvc pipes running from pump to and from inground pool...can I pull say a 1 and 1/2 hose through the pipe(50 feet long) and so have new non-leaking pipe without digging it all up?? near the pool pipe is under cement pad..what kind of pipe would pull through easy and what size??
rgebhard is offline   Reply With Quote
Old 06-25-2010, 10:47 PM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
I would say no. Your piping is sized based on the pump. If you restrict it too much, you could cause problems. I'm no pool guy, but that's pump basics right there.
Journeyman Plumber
Old 06-25-2010, 11:12 PM   #3
What size pump do you have - hp ?
Old 06-26-2010, 07:04 AM   #4
pulling new smaller pipe through existing line
pump is 1hp...a plumber here thought the same..that if you went down too much in size of pipe pulled through you could have problems...will see what other people think...
Old 06-26-2010, 07:35 PM   #5
My 1hp pipe was connected with 1.5" plumbing, not a lot of flow
The 1 hp was on a different filter, constricted the flow I think
My 1.5hp w/new filter is now on the same pipe & much better flow
Sump Pump Questions henlij Plumbing 22 03-16-2015 11:00 PM
swimming pool shaggysteele Electrical 6 08-04-2009 06:24 PM
swimming pool pump wire steel Electrical 5 04-06-2008 09:35 PM
sump pump continuing running deck hand Plumbing 2 01-16-2008 05:35 PM
Swimming Pool Light Broc Electrical 1 08-15-2006 03:23 PM
