Indirect Vs. Stand Alone Water Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-24-2008, 10:03 AM   #1
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,314
Indirect vs. Stand Alone Water Heater
Is an indirect water heater hooked up to an 80% efficient boiler the same efficiency as a separate 80% efficient water heater? An indirect heater has much better insulation than a standard so it doesn't need to cycle as often which also means it's standby losses are presumably less than a stand alone. When it does heat, however, it's running at 80% whereas stand alone water heater needs to cycle more often; at 80%?
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Installing a Tankless Water Heater infoiam Plumbing 4 11-10-2008 10:59 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
Water heater problem bear1957 Plumbing 23 11-01-2007 04:53 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
Draining a hot water heater singforsupper Plumbing 1 06-07-2006 07:01 PM
