-   -   Indirect vs. Stand Alone Water Heater (http://www.diychatroom.com/f7/indirect-vs-stand-alone-water-heater-32512/)
Clutchcargo 11-24-2008 10:03 AM
63 Attachment(s)
Is an indirect water heater hooked up to an 80% efficient boiler the same efficiency as a separate 80% efficient water heater? An indirect heater has much better insulation than a standard so it doesn't need to cycle as often which also means it's standby losses are presumably less than a stand alone. When it does heat, however, it's running at 80% whereas stand alone water heater needs to cycle more often; at 80%?
