Old 01-12-2013, 04:32 PM   #1
Indirect Fired Water Heater zone valve help.
I have a wood stove that help heat my home. but i have a oil bolier and a Weil Mclain indirect fired water heater gold plus 40 to heat my hot water. My 2 zone valves on the first floor and second floor are at the min setting 60 on the thermostats. I would like to know while the bolier is heating the indirect water heater is there a way to open the 2 zone valves even if the zones are not calling for heat. The Taco 1 Zone controls the hot water and zone 1 valve is a Taco 571-2 zone valve 2 is a Taco 572-2
and on the bolier is a Honeywell L8148A control. Here are some pic that might help. thank you
Indirect Fired Water Heater zone valve help.-004.jpg   Indirect Fired Water Heater zone valve help.-005.jpg   Indirect Fired Water Heater zone valve help.-006.jpg   Indirect Fired Water Heater zone valve help.-007.jpg   Indirect Fired Water Heater zone valve help.-008.jpg
brianna1 is offline   Reply With Quote
Old 01-12-2013, 05:36 PM   #2
Master General ReEngineer
Bondo's Avatar
Ayuh,... I'm sure it can be done, but I gotta question, Why ya wanta do that,..??
You'll use more fuel, as it'll be heatin' the house, whether it needs heatin', or not....
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 09:44 PM
LPG Water Heater Vs Indirect Water Heater rjordan393 Plumbing 2 01-31-2011 01:00 AM
water heater relief valve dripping (with gauge readings) ziguan Plumbing 10 01-28-2011 11:12 AM
water heater drip kdange1 Plumbing 5 05-04-2010 04:24 PM
