Increasing Water Pressure - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-21-2012, 08:30 AM   #16
Experienced
Jackofall1's Avatar
Originally Posted by jasin View Post
If the pipping is blocked from crud, corrosion, lime, rust, etc.. whatever, then why are all other pipes in the house not blocked?
They could be, they may be larger diameter and have not reached blockage levels that would create restrictive flow as of yet.
Who knows without the OP coming back and letting us know the whole story we are only speculating.
Mark
Old 02-21-2012, 08:41 AM   #17
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
You dont seem to be reading anything here because I already addressed shower heads and aerators. Also, with shower heads and aerators that conserve water ... the flow on them is reduced resulting in an increase in pressure. He does not have an increase in pressure though he actually has a decrease. So that's not the problem. As for a clog, it's very unlikely that is the problem either since water pressure is fine throughout the rest of the house.
No I said the clog could be at the fixtures themselves,which is very possible
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 02-21-2012, 08:44 AM   #18
plummen's Avatar
Sometimes certain fixtures get used more than others allowing crud to settle in certain areas,sometimes its just a matter of how the plumbing is layed out in the house
Old 02-21-2012, 08:48 AM   #19
Mark
Even if its blockage it would be, according to you, because the supply line is a smaller diameter pipe than all the other pipes in the house. You did state thats why all the other pipes are not clogged and the bathroom supply is. So he would still need to upgrade the supply line anyways. At least, if he wants to prevent this from occurring again. Your scenario is a stretch though as its based on an assumption and not anything factual.
jasin is offline   Reply With Quote
Old 02-21-2012, 06:25 PM   #20
Experienced
Jackofall1's Avatar
There is a double edge sword to increasing line size, yes the bore is bigger possibly prolonging a blockage, the caveat to this kind of change is you will reduce fluid velocity, which will actually increase the speed at which sediment will fall out of the fluid.
If sediment is the problem the larger lines would remain clear for longer not because they are larger, but because of increased demand (more points of use) thus increasing velocity through the pipe.
Again really only theorizing as we don't have the whole story, but as you can imagine increasing line size can and usually does hinder a sediment problem not fix it.
Mark
Old 02-21-2012, 06:45 PM   #21
Mark
Have you done an inspection on his plumbing?
Old 02-21-2012, 06:55 PM   #22
Experienced
Jackofall1's Avatar
Of course not, why would you even ask such a question. I am making a general statement to enlighten those who would possibly read this.
Mark
Old 02-21-2012, 07:08 PM   #23
Rewards Points: 616
sometime the less you say and the more they say can make you look more intelligent
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
The Following User Says Thank You to jaydevries For This Useful Post:
plummen (02-21-2012)
Old 02-21-2012, 07:59 PM   #24
Rewards Points: 268
There are a whole lot of houses out there that haven't had ALL pipes replaced. My house and my folks house both have all copper in the basement and first floor, then it's galvanized to the second floor bathroom...wasn't financially possible to replace at the time. In both cases the pressure is great everywhere except the second floor bathroom because the galvanized is all corroded internally.
Marqed97 is offline   Reply With Quote
The Following User Says Thank You to Marqed97 For This Useful Post:
jaydevries (02-21-2012)
Old 02-21-2012, 08:01 PM   #25
I never once stated its not a clog. Sure, it could be a clog. I did not ignore that possibility. I just simply stated based on the facts that its very unlikely that this is a clog. Its unlikely for the facts: the low pressure is isolated to one room, there are no restrictions in flow where the low pressure is, no clogs exist anywhere in the house, pressure and flow throughout the rest of the house is fine.
Hot water pressure problem (unusual situation) tanna Plumbing 2 09-03-2011 09:17 AM
System for increasing home water pressure? Daulton Plumbing 5 03-20-2011 11:35 PM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 02:02 PM
No water pressure in my pressure tank GordH Plumbing 6 05-18-2008 12:19 PM
New Help With Improving Water Pressure hayhursm Plumbing 1 01-31-2006 07:55 PM
